618 - Search - "Search in" field issue
Posted: 12.04.2013, 01:38
- go to path like "D:\Documents\Translations"
- open search dialog
- search anything (e.g. empty filename)
- press Escape to close dialog
- go up one folder, use just Enter key if possible, e.g. "D:\Documents"
= Search in field is not updated (to "D:\Documents", it's still the old path "D:\Documents\Translations")
If you skip the searching step, then the path is updated correctly.
Win Vista 32 bit.
Win Vista 32 bit.
