609 - last active file/folder filter is not set at new start
Posted: 07.05.2013, 10:37
by autocart
The last active file/folder filter (which was set at the last active session) is not remembered at a new program start (after closing and restarting the program).
(In the "old" version of FreeCommander it is remembered without problems.)
In the bug fixes since 609 did not show this problem as fixed.
Re: 609 - last active file/folder filter is not set at new s
Posted: 12.05.2013, 18:11
I the FC XE only reusable filters are saved and used for the new program start.
Posted: 13.05.2013, 07:20
by autocart
I retested it. With just one tab on each side it seems to work fine -> the set filter is remembered and restored at the next program start.
However, when I have two tabs on the left and one tab on the right, then the set filter is not remembered/restored for the 2nd tab on the left side. (The first one on the left and the one on the right have the filter restored to them correctly.)
Posted: 17.05.2013, 08:08
by autocart
Still the same, also in new version 620.
Posted: 06.06.2013, 11:23
by autocart
Version 625:
It works now!! THANKS!!
