Rel314: ALT-F9 will only be visible if folder is selected
Posted: 10.01.2008, 11:51
by Mr-Fly
Hi.
I dont know if this refresh issue is only on my PC, but I see with the latest release (314) that after pressing ALT-F9 or using "Folder/Size of Folders" that the size will only become visible, when I hoover the mouse over the entry or move the selection with the keyboard over the folder.
Regards
Thorsten
Posted: 10.01.2008, 15:24
by uwee
Not only you - same with me (on different computers).....
Posted: 27.01.2008, 10:51
by Mr-Fly
@marek
Any timeframe for a fix for this?
It is really hard to use this folder to eg. sort folders. even when deleting a folder, the list will get scrambled.
I have to always "walk" the cursor up and down over the dirs.
Posted: 27.01.2008, 22:30
It is already fixed. I hope, I can release the next beta in 2-3 days.
