628 - Focus issue on tab change
Posted: 11.06.2013, 19:46
The other focus bugs have been fixed, though I found one more:
- use list view, about 10 cm width
- create two tabs, lock both
- first tab should have just few folders and files
- [..] item must have 2 lines of status bar text
- on the first tab create a folder
- files in that folder must have 1 line of status bar text
- copy the test files so that the first column is full and the second column has one file if [..] is focused
- focus [..] item
- now press the right key to select the last file
- the number of status bar is changed from 2 to 1
- now switch to another tab and back
= whole panel is empty
It looks too complicated to reproduce, so in other words, the panel is empty when you select a file in the last column on first tab, then switch to second tab with 2 lines in status bar, then switch back to first tab - since the tab is locked, the path is change back from the folder with many files.
Another way is to use an archive with many files.
Don't know which method is clearer, I'll provide a video if needed.
I can always reproduce this bug.
Win Vista 32 bit.
- focus [..] item
Win Vista 32 bit.
