Safe mode (Kids mode)
Posted: 14.01.2014, 00:00
Such mode would be very useful for all users with children or any users which wants to protect their files (of course it can't be perfect, the files might be deletes with other programs and explorer).
I'm not sure about the name, here are some options: safe mode, read mode, kids mode, children mode...
I'll try to explain how it should work. It should be password protected, there should be the menu option, toolbar button, keyboard shortcut to enable/disable "safe mode".
If enabled, these options/actions should be disabled*:
- delete to bin, delete permanently, wipe
- move
- copy on the same drive ??
- drag&drop
- closing locked tabs
- address bar editing
- command line
- rename, multi rename
- limited access, only selected folders, or block specific folders - with option
- limited access, also for drives
- settings
- menu
- empty recycle bin
It should be clearly visible, that "safe mode" is enabled, message in the title bar, perhaps also different main program icon color might be used.
Perhaps another option would be needed, password protected settings folder, but not necessary, since it's mainly for children...
* You are welcome to add comments.
What do you think, is it needed?
- move
- drag&drop
- command line
- settings
- menu
- empty recycle bin
