Large drive icons FCXE-652 or FCXE-652x64
Posted: 22.01.2014, 21:21
Running FCXE-652 or FCXE-652x64 on Windows 7 Pro 64 bit, the large drive icons in the drive bar work great.
Running FCXE-652 or FCXE-652x64 on Windows 8.1 Pro 64 bit, the large drive icons in the drive bar are small and offset from the drive bar center.
The same icons are used on both systems.
Systems: Windows 7 Pro 64-bit SP1 and Windows 8.1 Pro 64-bit
