Disable Address Bar History & Popup List
Posted: 05.02.2014, 09:03
by Fad
Request to be able to disable the Address Bar History and Popup List.
Re: Disable Address Bar History & Popup List
Posted: 09.05.2015, 13:25
by dreamco
Fad wrote:Request to be able to disable the Address Bar History and Popup List.
That would be awesome
Posted: 09.05.2015, 21:47
by Free4all
dreamco wrote:Fad wrote:Request to be able to disable the Address Bar History and Popup List.
+1
I like the functionality, but I also want to be able to click on the address bar to select a pane without having anything popping up.
The history button gives you the functionality, and maybe that's sufficient.
Posted: 03.03.2020, 20:56
What about this option:
Settings > General > "Delete history entries on close"?
Not enough?
It's possible to hide the history on click in Settings > View > Address bar > General.
