Ini remapping bug
Posted: 30.01.2008, 15:21
Hi,
I found a wierd thing: Our users have restricted accounts, on Windows XP workstations. We deploy FreeCommander 2007.10a centrally, and relocate the INI file to C:\Docs&Settings\User\AppData folder. The issue is: if we do so, the left panel always show the working directory set in the shortcut to FreeCommander, so it will always overwrite the INI file, we can change the left panel starting directory only by altering the shortcut's properties. If we use the INI under Program Files\FreeCommander, and give write rights the users to that file, everything works fine.
Can you help me?
Thanks in advance,
Ok0ska
Can you help me?
Thanks in advance,
Ok0ska
