654 - Hidden items have the same icons as normal items
Posted: 06.03.2014, 02:20
Hidden and system items have the same icons as others, the icons are not semi-transparent as in older versions.
Re: 654 - Hidden items have the same icons as normal items
Posted: 06.03.2014, 06:26
by Timon
Confirmed.
Posted: 06.03.2014, 08:01
I'm not using too much hidden files or folders, so I don't remember exactly how they looked before, but their icons definitely have a lighter color in 654 (default settings + show hidden files) in my case.
Posted: 07.03.2014, 00:14
OK, so it works good with default settings, I tried the NC mode, but it must be another option...
Posted: 07.03.2014, 05:14
by Timon
Yes, in NC-Mode there is no difference.
Posted: 08.03.2014, 00:53
Got it! It's the option "Use Windows colors", disable it (and refresh view) to reproduce.
Posted: 08.03.2014, 11:43
Nice job! Confirmed!
Posted: 09.03.2014, 02:21
The icon is not changed also when using "cut", ctrl+x.
