"Views" popup menu (action toolbar->View->views) bug
Posted: 21.03.2014, 06:08
FCXE650: There are two problems with this command option. (1) There is no icon set for this option, so toolbar shows blank box for this command. (2) The popup shows only "List", "Details" and "Thumbnails" view options, no "small icons" or "Large Icons". FC2009 did show the popup menu with all 5 of the view options and had the icon shown properly. Thanks for your attention.
Edit: Ok, I forgot about the "details" column for the command. I thought the icon would be set by default, I had to set the icon manually and use the system icon in the system32 folder. I also had to add the view options "Small/large Icons" myself, which I thought would be set by default. Anyway problem solved.
