File icons flicker when set to Extract
Posted: 16.04.2014, 12:17
Some file icons (exe, url) were flickering every 3 seconds or so (though times varied slightly) when set to Extract icon.
Noticed in 64 bit donor, found also in standard donor version.
Change setting to registered icons, flickering stopped.
Tested with default settings and without plugins, still occurred. Then after a little while flickering stopped.
Realised it was due to multiple files downloading into same folder, as soon as finished, flickering stopped. Tested with single file download, occurred but less frequently.
Windows 7 Pro 64bit
FC XE 2014 build 658 donor & FC XE 2014 build 658 (x64) donor
Windows 7 Pro 64bit
