Selecting multiple files with - keyboard shortcut?
Posted: 13.07.2014, 11:17
Hi all,
I'd like to ask about the keyboard shortcut for selecting files (and folders) in FreeCommander XE. I'm using "FreeCommander XE 2014 Build 650".
I used Servant Salamander as my file manager in past, now I've got a new PC and decided to give the Freecomander a chance as it looked very good. So I'm a newbie with FC and kind of a noobish is my question:
How do I select multiple files using a keyboard?
Here's what I mean - main reason I'm using different file manager than Windows Explorer is that I'm a photographer and I need to manage my photos very often. Usually I need to delete photos from the card that I don't want to keep and fastest way is to select them with a key and then delete them all in one click (keypress). Many file managers (Total Commander, Servant Salamander, even the Norton or Volkov Commanders in DOS) use the "INSERT" key for this function.
In FC I haven't found yet how to do this. Of course I know I can select multiple files by clicking left mouse button while I'm holding the CTRL key, but I don't want to use my mouse to select files because it's much slower.
Am I just so dumb or FC doesn't provide this option?
Any help will be much appreciated.
Thanks.
Thanks.
