Desktop Icons not showing in Desktop
Posted: 10.09.2014, 16:58
I have noticed that for a long time (I have version 669, 32bit at the moment) that when I go the the Desktop in FC, it does not display all the shortcuts that are on the Desktop. I can see more icons in explorer than in FC.
As far as I can tell, the problem is only with shortcut files
I recently installed a program called MarkdownPad 2.
The filename is
The target location from the shortcut file is:
The file shows in Windows Explorer but not in FC.
There are several other shortcut files that also do not display.
Refreshing has no effect either.
And the non-displaying of the icons is persistent over restarts. I've had this problem in FC for years, actually.
But there are a few shortcuts that do show up in FC, and they are .lnk files too. But it seems the the problem stems mostly from shortcuts created by application setup installers.
The filename is
C:\Users\Public\Desktop\MarkdownPad 2.lnkCode: Select all
"C:\Program Files (x86)\MarkdownPad\MarkdownPad2.exe"There are several other shortcut files that also do not display.
