Use for full subfolder path : won't actually match full path
Posted: 06.10.2014, 17:24
So it's there in build 673 ! (FreeCommander XE 2014 Build 673 donor, Windows 7 32 and 64-bit) :
- Implemented: New search option "Use for full subfolder path (otherwise only for subfolder name)"
(Thanks !)
Though, when I test it against the following use case (pattern \d{8}) :
...my candidate2.txt file won't come up although it (seems to) match the path regex (?)
I also tried regex .*?\d{8}.* just in case
(Thanks !)
.\20140930
.\20140930\candidate1.txt
.\non_date1
.\non_date1\non_candidate.txt
.\non_date2
.\non_date2\20141006
.\non_date2\20141006\candidate2.txtI also tried regex .*?\d{8}.* just in case
