FreeCommander XE "not so obvious" settings
Re: FreeCommander XE "not so obvious" settings
#46 Post by Dreamer » 16.02.2024, 21:20
It's possible to use external programs in FreeCommander, to add new features, or to enhance existing.
Thanks to the new built-in icons added in build 903 donor it's now possible to use the icons with the same style as in FreeCommander.
For example, it's possible to create a multimedia toolbar, which can be useful for users without multimedia keyboard, or/and to control any audio/video playing in any window, even on another display, it can be useful also to quickly pause or stop video playing in web browser with many tabs.
Here is a simple guide, how to create a multimedia toolbar in FreeCommander, using HotkeyP:
- download HokteyP
- unpack it to e.g. C:\Tools\HotkeyP (don't use "Program files" folder)
- in FreeCommander - menu - Tools - Favorite tools - click to "Favorite tools edit"
- create multiple items for any toolbar, existing, or new
For these actions just copy/paste the text to appropriate field (edit HotkeyP path, if needed):
Name:          | Program or folder:           | Parameter:
Play/Pause     | C:\Tools\HotkeyP\HotkeyP.exe | -macro \play_pause
Stop           | C:\Tools\HotkeyP\HotkeyP.exe | -macro \stop
Previous track | C:\Tools\HotkeyP\HotkeyP.exe | -macro \prev_track
Next track     | C:\Tools\HotkeyP\HotkeyP.exe | -macro \next_track
Volume -       | C:\Tools\HotkeyP\HotkeyP.exe | -Volume - 2
Volume +       | C:\Tools\HotkeyP\HotkeyP.exe | -Volume + 2
Mute           | C:\Tools\HotkeyP\HotkeyP.exe | -mute
For icons the built-in icons can be used, next to the Icon - File - click to button [...] - Built-in icons and then select icon in the Icon pane.
Note: It's possible to use just 1-state icons, so the icons will not change on click.
Final multimedia toolbar could look like this:
FreeCommander Multimedia Toolbar.png (3.69 KiB) Viewed 75156 times
Of course, any custom, external icons can be used too.
#47 Post by Dreamer » 16.08.2024, 23:34
- Changed in 912: Settings - changing the start background color now always changes the end color. This is controlled with the freecommander.ini option “AutoSetBackgroundEndColor=1”; default is 1 (true)
#48 Post by Dreamer » 10.11.2025, 21:57
Implemented in 938:
Tree - Ctrl+Click on expanded node collapse all subnodes
#49 Post by Dreamer » 07.03.2026, 16:18
Implemented in 946:
Viewer - option added in the freecommander.ini in the section [TfcViewerForm]: ActivateCropOnImageLoading=0
Use value "1" to enable crop mode automatically.
Users browsing this forum: Amazon [Bot] and 1 guest
