674 - Multiple filters ignored
Posted: 26.10.2014, 13:16
Everything after the first ; is ignored.
Tested with build 674 x86 and x64 using default settings on win7x64sp1:
Re: 674 - Multiple filters ignored
Posted: 26.10.2014, 14:47
It seems, the blank is not ignored, try:
*.amr;*.aiff;*.aac;*.flac;*.m4a;....
Posted: 26.10.2014, 17:02
You're right, it works fine without the spaces.
So, is this going to change back (is it a bug?), or should I change all my filters? Note that the tooltip with the examples should be changed, too, if this change is final.
Posted: 26.10.2014, 20:29
I am not sure, what is better. If I ignore blank, you can not filter for files with blank at the beginning ' myTest.*'.
Posted: 26.10.2014, 21:13
I see no point of having a file name that starts with a space, but that's just me.
I'm used to the way it worked before (multiple filters separated by ; and spaces), but now that I think about it, I don't really see the need for 2 separators (; and space).
I'll wait for your decision in the next build.
Posted: 04.11.2014, 13:59
Fixed in 675. Thank you!
