Translation string missing?
Posted: 21.11.2014, 14:43
Build 680 - Translation string appears to be missing for the example text in the dialog box that opens when Alt-F5 keyboard shortcut is pressed (add to archive dialog box).
Welcome to the FreeCommander forum!
https://freecommander.eu/
Do you see, that examples in that strings are different?What about the rest of the string, like in numbers 50010, 54013, and 62106?
34827=%s Object(s)Also, where is the string for status bar text 'Object(s)'?
Right. The example for 57015 seems to be missing.Timon wrote:Do you see, that examples in that strings are different?What about the rest of the string, like in numbers 50010, 54013, and 62106?
Thank you!Timon wrote:34827=%s Object(s)Also, where is the string for status bar text 'Object(s)'?
That item is applied only once, after first program startup (that item is written in ini file). If you change it later, it would be not applied (already reported Marek about it). So if you want to change it, delete all setting and after that run program again.
There is nothing more to translate in all that items except the word "Example".Right. The example for 57015 seems to be missing.
Right. But generally string resource files contain all the strings for easier and more efficient maintenance. Plus, consistency helps avoid errors (the other strings include the examples).Timon wrote:There is nothing more to translate in all that items except the word "Example".Right. The example for 57015 seems to be missing.
