No more internal file identifiers available
Posted: 08.12.2014, 22:43
by jackstraw
Got this error pop-up in FC-XE-2014-682-x64-donor when I inadvertently had the same directory on both right and left, and attempted to copy a file from right to left. Running on Win 8.1 Update x64. Was able to reproduce at will copying other files in other folders. This may be the intended message to flag this user error, if so it could be made more clear. Thanks.
Re: No more internal file identifiers available
Posted: 09.12.2014, 02:45
I have another error message in 682 64 bit:
"The process cannot access the file because it is being used by another process"
Anyway, this message is not correct either. The correct message is shown when using move operation:
"Source and target are the same - operation is not supported"
Perhaps it should say "operation is not possible".
