682: Context New Menu will handle new Documents different
Posted: 13.01.2015, 10:46
Hi.
If you use right click and "New", the menu might show Files, that have Templates somewhere.
In my case it was:
C:\ProgramData\Microsoft\Windows\Templates\MM14 New Map.mmap
This file was Write protected.
If I use explorer New-Menu, the file will be copied and the Read Only Flag will be removed by explorer.
If I do the same in FC, the file will be copied, but the Read Only Flag WILL NOT be removed. Ending in using the FIle write protected when opening it.
I think the default for a new file build out of a template should be to be not write protected.
Regards
Thorsten
In my case it was:
Regards
Thorsten
