Search files/folders - Profiles suggestions and improvements
Posted: 15.01.2015, 17:12
#1 - Place the Profiles field with drop-down menu on the mail, first Location tab too. *
#2 - Add option "Activate Profiles combo first". *
#3 - After double-click the profile, automatically activate selected profile and change tab to first, Location. *
#4 - Add option "Quick viewer horizontal". *
#5 - Save Quick viewer status on dialog close and FC close. *
#6 - When I select the profile and click the Find button, profile is activated and tab is changed, but search is not started, I suggest to start searching either.
#7 - Add option "Start with last used settings". *
* These suggestions and improvements work the way I'm requesting already in the multi-rename dialog, they would be useful also in the search dialog.
