Some Files are not visible with 64Bit version
Posted: 19.01.2015, 03:03
by Tronic
I recognized that some files are not visible inside the 64Bit version of FC XE.
In explorer and the 32Bit version the same files are visible. You can see it on screenshots below:
http://imagizer.imageshack.com/img912/8463/Zew0yC.png
http://imagizer.imageshack.com/img633/8372/hN9qn4.png
Thanks in advance!
Kind regars,
Tom
Re: Some Files are not visible with 64Bit version
Posted: 19.01.2015, 08:09
And this happens using FC XE 64 bit with default settings, also? Please, try the portable version with default settings if you haven't already.
Maybe you've accidentally activated a filter for excluding files containing "it" or something...
I recreated those file names on my machine and they are visible within FC XE 64 bit (default and custom settings).
Posted: 19.01.2015, 10:21
Are the files marked as hidden/system?
