Quick View Panel Using Windows Media Player Crashes
Posted: 31.01.2015, 18:29
by Max Headr00m
I use visualizations from sound spectrum (G-Force & WhiteCap) in Windows Media Player. The visualization installer installs both 32-bit and 64-bit versions. I have the latest versions installed. When the visualization in Windows Media Player is set to either one of these (G-Force or WhiteCap) and I try to play a media file in the quick view panel, it crashes. This only happens in FreeCommander XE 64-bit (Using the latest version Build 685 64-bit donor). It works fine in the 32-bit version. If I change the visualization to one of the built-in ones (Alchemy, Battery, etc..) it works fine. On a related question, is it possible to make the quick view panel use J. River Media Center to play files?
This is the problem details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: FreeCommander.exe
Application Version: 2015.1.0.685
Application Timestamp: 54ba4391
Fault Module Name: WhiteCap.x64.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 54b5cb80
Exception Code: c0000090
Exception Offset: 00000000002b59df
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 221c
Additional Information 2: 221cc3e011f478abdb61aaeead4ec5fc
Additional Information 3: 7f8d
Additional Information 4: 7f8d095552c9ec4a9640c9d94747b136
