Isn't RAR supposed to show as folder, like ZIP?
Posted: 18.02.2015, 12:02
by dsperber
Aren't RAR files supposed to be presented as folders in the Explorer Tree pane, which when selected are then supposed to show the expanded contents in the Details pane... exactly the same as with ZIP files?
Doesn't happen. What am I doing wrong?
Re: Isn't RAR supposed to show as folder, like ZIP?
Posted: 18.02.2015, 19:38
by dsperber
Anybody??
What do you show with RAR files? Do you see a "folder" in the tree pane (same as ZIP shows) or not?
I'm certain both ZIP and RAR were intended to behave the same, but they're not.
Posted: 18.02.2015, 19:40
dsperber wrote:Aren't RAR files supposed to be presented as folders in the Explorer Tree pane...
I don't think they are...
Posted: 18.02.2015, 20:05
by dsperber
So the "archiver plugins" (which apparently support both ZIP/JAR/WAR and RAR) are only to provide expansion in the details pane?
Instead, only ZIP and CAB deserve "folder" presentation in the tree pane?
Seems very inconsistent. I can't imagine justification for why at the least ZIP and RAR should not be treated identically in both panes.
I hope Marek sees this discussion and comments.
Posted: 18.02.2015, 21:58
ZIP and CAB are natively supported by Windows.
Adding other archive types to the tree would make the tree much slower.
