Ctrl-Q problem in Windows 7
Posted: 19.03.2015, 00:30
Hi All
I often use the shortcut Ctrl-Q to preview images in a quick preview panel. It works perfectly in Vista, but recently I got another PC with Windows 7. The shortcut Ctrl-Q does no work at all. However I can open a quick preview panel if I use menu View -> quick preview panel.
I copied all settings from my freecommander XE installed in Vista to Windows 7, but it did not help.
Could you please advise how to fix the problem.
Thanks.
Thanks.
