Portable downloads, there are two of them
Posted: 22.03.2015, 08:03
by bawldiggle
On http://freecommander.com/en/downloads-portable/ ...
... what is the difference between
  • • FreeCommanderPortable_2015_Build_685.paf.exe
    -AND-
    • FreeCommanderXE-32-public_portable.zip
I am using extracted portable FreeCommanderXE-32-public_portable.zip
Thank you :)
SPECS:
Win7 Home Premium -- 32-bit
FreeCommander XE 2015 Build 685 32-bit public (portable)
ClassicShell "Classic Start" and "Classic Explorer"
Toshiba Satellite C665
Re: Portable downloads, there are two of them
Posted: 22.03.2015, 09:12
The .paf extension is mainly used by portable applications in PA.c format, better suited to be used with the PortableApps platform (although they can be used as standalone apps).
If you don't use that, the .zip file is what you need.
