Missing folder icons for system folders (and some others)
Posted: 28.04.2015, 18:18
by jaden
The folder icon is blank for certain folders. It seems like only read only folders, but I can create a read-only folder and the icon doesn't go away. This just started happening and I verified that it still happens with a fresh FreeCommander (i.e. no settings).
Here's a screenshot in case it helps.
Screenshot - 4_28_2015 Tue , 12_16_34.png (6.76 KiB) Viewed 18463 times
Build 690 64-bit on Win7 x64.
Re: Missing folder icons for system folders (and some others
Posted: 28.04.2015, 20:16
Are those hidden folders?
Posted: 28.04.2015, 20:26
by jaden
Some are, but not all of them. And one missing folder icon is on a folder I created.
Posted: 29.04.2015, 07:42
I'm also using build 690x64 on win7x64 and can't replicate the issue.
Did you try the portable version, just to make sure it uses the default settings?
Posted: 29.04.2015, 19:13
by jaden
I did use a freshly downloaded portable version. I just tried again, this time with the 32-bit version as well as the 64-bit, and the 32-bit version didn't have the problem - the folder icons showed up for all folders. But the 64-bit version still had missing folder icons.
Like I mentioned, the common element seems to be when the folder is marked read-only, but making a folder read-only doesn't create the issue.
Without showing hidden files or system files, the two folders that have this problem are C:\Recovery and C:\Config.Msi. They both have the following attributes:
Archive
Read only
Hidden
System
I created another folder and set those attributes, but the folder icon shows up normally.
I'd be happy to provide more information to help debug it.
Posted: 30.04.2015, 07:36
Maybe Marek can replicate this issue and can debug it. I can't replicate this on my system.
Posted: 02.05.2015, 20:18
What about the tree? It is local drive?
Have you checked Settings->File/folder list->Icons: Registered (Extracted)?
Posted: 08.05.2015, 18:40
by jaden
Yes, both my drives are local, and both have the missing folder icon. The tree view doesn't have the missing icons.
I didn't realize there were File/folder list->Icons settings. But Fixed Drive had Extracted Icons and the other three had Registered. I switched Fixed to Registered and the icons appear again.
I don't recall ever changing that setting and folder icons have been showing up fine for years, but thanks for the pointer! :)
Re: Missing folder icons for system folders (and some others)
Posted: 19.06.2018, 11:55
by Peter_HH
Hi Marek,
I am a new user and have the exactly same problem. Tree shows icon for folders, but not all of them same in the filelist(s)-tabs. Some folders you see the icon only a milisecond and the are gone.
The folder are normal folder on my local drive, self created onces.
I can't find the menue here what was mentioned in Donor version 770. How to fix? Had same problem with free version and older version.
I donated it and I am just checking if this is worth to keep trying on to replace the standard I used (DirOpus as bougth version).
Only one point I found is - that I can't queue copy jobs, as I had some more files and dirs to move. Maybe I didn't yet found it?
+ the point of missing icon for folders which is a big issue/bug for me.
Posted: 19.06.2018, 12:26
If you can not find "Settings->File/folder list->Icons: Registered (Extracted)": https://freecommander.com/fchelpxe/en/Icons.html
Posted: 19.06.2018, 12:31
by Peter_HH
Thanks Karol. It helped me to find the settings.
:-) Set to "Registered" and it works now.
Found copy-queues as well :-D
