uLister Plugin at end of list takes precedence
Posted: 01.05.2015, 02:48
by BGM
There is this one plugin called uLister that can open most files, but can't open wav files.
I put it at the end of the plugins list.
Now, I want plugins to have a higher priority than internal viewers, so enable that option,
but for wav files I want to use the internal viewer by default instead of the plugins.
Is there a way to use the "detect string" for the plugin to *exclude* a file type?
Re: uLister Plugin at end of list takes precedence
Posted: 01.05.2015, 16:55
by horst.epp
BGM wrote:There is this one plugin called uLister that can open most files, but can't open wav files.
Add the Total Commander Mmedia plugin from the following URL:
http://fg.tcplugins.free.fr/mmedia.htm#3
and move it on top of your plugins.
Posted: 01.05.2015, 17:05
by BGM
I actually have mmedia - I just found it last night in 64bit.
I had to use a "detect string" of "MULTIMEDIA" to get it to take precedence over ulister even if ulister was at the bottom.
Posted: 01.05.2015, 18:08
by horst.epp
BGM wrote:I actually have mmedia - I just found it last night in 64bit.
Of course you have.
But this is the default after the installation, at least for me.
Posted: 02.05.2015, 00:08
@BGM Please, take a look at my edit in this post (I had a similar issue): http://forum.freecommander.com/viewtopi ... 269#p18269
Posted: 02.05.2015, 02:29
by BGM
Thanks Joby - I took up my position at the tail!
