XE feature request: create shortcut via hot key
Posted: 06.05.2015, 09:43
Is there a way to create a shortcut via hot key or "EDIT"-menu?
I'm a friend of keyboard-navigation, so I hoped there is something like "CTRL+ALT+F5" I know of TC.
Now I'm working with Drag&Drop plus "ALT" to create a shortcut to a file or folder or I use the context menu option and move it to the other window manually.
Best regards,
mihee (a former TC user
Best regards,
