Windows XP and Classic themes - no separators
Posted: 07.05.2015, 18:35
by LPoor
FreeCommander XE with themes Windows XP and Classic doesn't provide separators between 'Menu bar' and 'Actions toolbar', and between 'Actions toolbar' and 'Drive bar'. FreeCommander 2009.02b provides these separators.
How to make it in XE ?
Re: Windows XP and Classic themes - no separators
Posted: 07.05.2015, 19:44
Is this what you're looking for?
Posted: 08.05.2015, 12:59
by LPoor
Thank you but it doesn't help. I asked about:
FreeCommander XE:
FreeCommander 2009.02b:
Posted: 08.05.2015, 14:06
This is how it looks for me with those settings above and Classic view style:
Posted: 08.05.2015, 14:17
by LPoor
Thank you,
but I prefer to have exactly the same view like it is in 2009.02b .
Posted: 08.05.2015, 18:30
If I uncheck "Show menu as toolbar" I get this:
Maybe I don't understand what you're searching for exactly... I'll try to recreate your "very flat" view.
Posted: 08.05.2015, 18:37
by LPoor
'Menu bar', 'Actions toolbar' and 'Drive bar' are separated from each other by long line.
Posted: 08.05.2015, 18:56
I can recreate your flat view only when I use "Show menu toolbar as - one wrappable toolbar" option.
If I use "Show menu toolbar as - many toolbars" option, I get the spacers you're looking for:
...and this is the view using "Windows XP" style (I can see some separators there):
Posted: 11.05.2015, 20:06
by LPoor
Thanks,
but in 2 panels view it looks badly.
That's the case when the old is better than new (02b vs XE).
