Make folder list create .tmp file automatically
Posted: 08.05.2015, 10:03
When I use the「Make folder list」function, it create .tmp file ( fc3D08.tmp,fc3F0B.tmp,fc41CB.tmp,...etc.) in the "from:" path automatically, is it normal? or a bug?
https://www.flickr.com/photos/mjmonica/17458108836/
thanks
FreeCommander XE 2015 Build 690 64-bit donor,Windows 7 SP1 64-bit
thanks
