"New Folder" generates dir with wrong name in FC v685
Posted: 10.05.2015, 20:27
Error with FC v685, (same actions works without problem in v650):
In folder
(still not too long, "only" ~155 chars) I use context menu to generate new folder, enter as name, then OK, but generated folder is
I could provide screen shots and my used configuration if needed.
FC v685
Win7-64-Ult SP1
In folder
"C:\Users\Hans\Documents\very_long_dir_____________________________1\very_long_dir_____________________________2\very_long_dir_____________________________3"Code: Select all
"FreeCommander_v685_new_folder_test"Code: Select all
"very_long_dir______________"FC v685
Win7-64-Ult SP1
