Need Relative Path ability
Posted: 15.05.2015, 00:24
I want to use FreeCommanderXE, but I need to be able to use it on 100% portable USB sticks at multiple sites where I am using other people's computers and I do not have administrator rights. I see old posts suggesting using drive renaming schemes, but that will not work for my needs.
In Total Commander (TC), they use a method called the "Button Bar" into which you put your apps address from which you can click on the button icon and run the application. For example only, I use a text editor as follows:
%COMMANDER_PATH%\Metapad\metapad.exe
When I use TC anywhere from my USB stick, this relative path works. Is there something similar in FC?
Tks for listening.
Tks for listening.
