No Split File ?
Posted: 28.05.2015, 16:51
by PnYMaT
Hi,
I just install last Free Commander XE (XE 2015 Build 685 32-bit public) and in menu i can't find Split File option. This feature does not exist ?
Re: No Split File ?
Posted: 28.05.2015, 21:08
Not yet.
Re: No Split File ?
Posted: 28.05.2015, 22:08
by PnYMaT
Ok thanks, i will wait
Re: No Split File ?
Posted: 29.05.2015, 07:53
by PnYMaT
Mmmhhh it is strange or i do not understand, but this topic of 2008 talk about the split function.
http://forum.freecommander.com/viewtopi ... plit+files
The possibility as withdrawned ?
Re: No Split File ?
Posted: 29.05.2015, 08:53
In FC XE this option is not implemented yet. Use
FC 2009 until then.
P.S. FC XE is not a new build of FC 2009. It is an evolution, but still, a completely rewritten software. Not all features are implemented yet. They will be, but it takes time.
Re: No Split File ?
Posted: 29.05.2015, 10:12
by PnYMaT
joby_toss wrote:In FC XE this option is not implemented yet. Use
FC 2009 until then.
Hi,
Ok i understand now, many thanks for informations, i am not yet aware of Free Commander history
