To be able to define keyboard shortcut with Esc
Posted: 26.06.2015, 16:01
If you want to change a keyboard shortcut to Esc (eg. Unselect all -> Ctrl+Num-)
you are unable to write Esc in the "New shortcut" editbox, because the dialog closes on pushing Esc.
FreeCommander XE 2015 Build 685a 64-bit donor
