693 - FC Locking files
Posted: 29.07.2015, 19:10
This has been happening somewhat randomly for the last few releases. A few other applications I use that check for file locks before accessing files are displaying a "file is currently in use by" error with the username and computer blank.
I initially used the Windows Process Explorer (procexp.exe) to find the file in question and the FreeCommander.exe process has the file handle locked.
Since then when a file lock error occurs I just exit freecommander and the file is unlocked. Rebooting does not help. OS = Win7 64bit.
