Rename target file in Pack files dialog impossible (695 x64)
Posted: 03.09.2015, 07:19
Hi,
I am using Build 695 64-bit donor and think I have come across a bug.
I back up files daily to a network drive like this:
* Open the source and target folders in dual pane mode.
* Select the file to be backed up in the source folder.
* Press ALT + F5 to launch 'Pack files' dialog.
* In the target field of the dialog, add a timestamp to the name of the Zip archive to be created.
This version of Freecommander ignores any changes to the target file name - the name will be the basename of the selected file with the extension 'zip'.
I have been using Freecommander (the best thing since sliced bread) for over 5 years and used the above-mentioned process daily...so this is a new bug (or regression?), because earlier I was able to rename the target in the Pack files dialog.
With best regards and a huge thank you for an excellent piece of software.
Joq
Proud donor
Joq
Proud donor
