sorting file by tokens contained in the name
Posted: 24.09.2015, 19:47
Ciao to all!
I'm new to this program, I see it has a lot of features so I ask to you all if it implements a feature it's a long time I'm looking for.
I have some plots of some electrical measurements ("_" is the separator)
I'm looking for a feature to sort the files (which will be then sent "in sequence" to an image viewer) according to one/more token(s) contained in the name
For example:
- Sort by token#2 will provide to me the ability to inspect how the devices-behaviour keeping constant the temperature
- Sort by token #3 will provide me to "pack" the plots based on the tension...
I hope my request is clear!
Let's see
Ciao and thanks!
Andrea
For example:
Let's see
Ciao and thanks!
Andrea
