697-'Right align extension' stops working with long .ext
Posted: 30.09.2015, 17:50
FC XE 697 donor x86 under Windows XP SP3
'NC mode' and 'List view' are used for FC XE
In Tools - Settings... - View - File/folder list - 'Right align extension for details and list view' is switched on.
See screenshot http://snag.gy/ou20K.jpg
It works fine in almost all cases (if file extension is about 8 characters, everithing is fine, look at file 'logo_test.PlayList' on screenshot). But if extension is rather big (11 characters in my case) it stops working for that particular file in FC XE.
As you see, extension of file 'app.connections' on screenshot in FC XE (on the left) is not right aligned; in Total Commander (on the right) the same file with the same alignment is shown is it should be (Brief view is used for Total Commander).
