include visibility of custom toolbars in layouts
Posted: 24.10.2015, 23:30
Hi,
I have quite some scripts for special tasks on files, like resizing, cropping, ocr, archiving, versioning, creating, combining, analysing, whatever you may imagine....
I use fc to show and select the files, and I use custom buttons to start the scripts.
There are quite a number of these scripts, and I use big icons to clearly visualize the tasks behind the button... That means that these buttons are occupying quite some space. And their number makes it sometimes quite demanding to find the correct button...
Since I have the files stored depending on their type (e.g. all pictures in a folder, all scanned in another folder) and/or depending on a certain topic, I use some layouts to show the most important directories in tabs.
I would appreciate if also the toolbars could be made visible or invisible, dependent on the active layout. This would spare a lot of space, reduce the time for searching the correct button... Why cluttering the toolbars with buttons which only make sense for some very special files in some special folders, which are rarely used?
