Main window title - Pattern
Posted: 01.11.2015, 17:45
FC XE 700 donor
If in Tools - Settings - View - Main window title - Pattern - I set [path] [platform][release] or [path] [release][platform] (no matter what is the order of [platform] and [release] is used)
then I see rather strange info ('C:\Program Files' path is opened in active tab)
C:\Program Files 700 - Free Commander XE 32 bit (in both cases)
See http://snag.gy/lZfoD.jpg
I'm sure it should be
C:\Program Files - Free Commander XE 32 bit Build 700 donor (in first case)
or
C:\Program Files - Free Commander XE Build 700 donor 32 bit (in second case)
or something similar ([platform] and [release] should be shown after 'Free Commander XE' in both cases)
May be there is need no show 'public' for that kind of releases and 'beta' status.
In other file managers it is shown exactly that way. See http://snag.gy/ZZp6B.jpg
or
