Filename extensions have moved to the right
Posted: 27.11.2015, 17:05
Beta 702 x64
Since updating all the filename extensions have moved to the right - separated from the filename itself.
How do I make them return to being attached to the filename ?
I have tried using the Windows "filename" option in column profiles, but then I cannot remove the FC "Name" column - it seems to be hard coded and unable to be deleted.
