bug: folder tree display visible after toogle dual/one panel
Posted: 05.01.2016, 18:48
by NumberOne
folder tree display becomes visible after toggling dual/one panel if favorite items tree is set to "one tree per panel"
Re: bug: folder tree display visible after toogle dual/one p
Posted: 06.01.2016, 00:10
by NumberOne
apparently there is an issue when clicking toggle folder tree display when "Follow location changes in the active panel" is unchecked. I PMed you two crash reports....
Posted: 06.01.2016, 14:51
Fixed for the next release.
It is not to reproduce for me.
From the report you have send to me I can see that the exception is not directly in the freecommander code.
What could you check: try to set the base folder for the tree to "computer" or "drive" and check again.
Have you some exceptional drives or other nodes in your tree?
Posted: 06.01.2016, 23:52
by NumberOne
I ran XE in a virtual machine. the tree contains the network node, maybe that's the reason? ( I'm just gessing)
I get back to you if I can reproduce the issue on my local machine.
