Simple file rename question
Posted: 06.03.2016, 14:48
I'm almost embarrassed to ask, but....
I'm used to renaming files in Windows Explorer by highlighting a file then clicking on the file a second time to go into edit mode. That doesn't seem to work in FreeCommander - is there a setting for this or is this function not available? Changing the setting "allow rename on slow double click" doesn't seem to do anything, and I can't find any other relevant settings. I'm running the 32 bit version XE 2016, Build 715.
Any help would be appreciated - I would really like to make this work! Thank you.
