How to open folder in left or right panel - by the choice of
Posted: 10.03.2016, 20:57
I would like to know if there is a way for an icon in favorite toolbar to open a folder in precisely left or right panel
Right now FC opens such a shortcut in an active panel; so sometimes in left and sometimes in right, depending on my current active status [workflow]. But I would like FC to open it always in right or left. I already have the same folder shortcuts on the left and on the right, to make less movement with mouse- but without sticking the opening of those shortcuts on the right to the right panel and the left shortcuts to left side of the screen- such a time saving help is simply not working as it is indented to
I've tried applying to an iconbut it doesn't work
Start folder" %RightDir%
Parameter: %RightDir%
