"Active file container Tab"
Posted: 08.04.2016, 08:39
by dxcarnadi
Hello
I can change the background color of the Active Tab.
But the background color of the "Active file container Tab" cannot be changed.
Why?
I cannot read the words in the "Active file container Tab" because the contrast ...
What can I do to change the contrast? Thank you.
BTW .. how can I upload a screen-shot picture to the forum?
Re: "Active file container Tab"
Posted: 08.04.2016, 17:51
It works fine for me in build 716 public, on win7x64. What's yours?
P.S. I upload the screenshots to imgur and post the link here with [img] tags.
Posted: 08.04.2016, 20:33
by dxcarnadi
@joby_toss
I use FreeCommander XE 2016 Build 715 32-bit public.
I think .. in your picture "Active Tab" is D.TmpFileContainer-1.fcc
and "Active file container Tab" is D:\...\SETTINGS\FileContainers\..
You've changed the color to green .. why is "Active Tab" green.
I'm confused!
BTW which one of these 3 items should I click?
Background start
Background stop
Highlight
and "Apply" ... "OK" ...
but I cannot change the second line .."Active file container Tab"
Posted: 08.04.2016, 23:02
I think you just click in the wrong area. You need to click the color button next to the preview image, then...
Font - is the text color
Background start - is the first background color
Background stop - is the second background color
Highlight - is the color when you go with cursor over the tab
You can use the same color for background start and stop, or use similar colors, to have a nice effect, use different colors for background start/stop and font, don't use dark for both, for example.
BTW joby_toss used green color just to show you how to change it, you don't need to use green, of course.
Posted: 09.04.2016, 13:01
by dxcarnadi
I want to change the background color of the line BELOW the yellow "G:Wu"....
from blue (G:\_No-XXX\Books\Java\Java 1 sources\Wu) to green.
Is it possible?
How? Thank you.
Posted: 09.04.2016, 13:52
Settings - Address bar - Color/font http://www.freecommander.com/fchelpxe/e ... rFont.html
Posted: 11.04.2016, 11:06
by dxcarnadi
@Karol
Thank you for the lead to the online help.
