Wherehis view folders as files?
Posted: 12.04.2016, 05:18
by rk31502TZ[
I have used FreeCommander for years.
This laptop I am using has FreeCommander but I can't find a way to view folders as files which I had used for all that time. Am I missing something hiding in plain sight?
Richard
Re: Wherehis view folders as files?
Posted: 13.04.2016, 21:21
Settings > View > File/folder list > Sorting
Posted: 19.04.2016, 22:29
by rk31502TZ[
In View I have-
plain view- files
plain view- folders
plain view- files, folders
No view files as folders.
Is there anything else I can try?
Would uninstall/install be l be likely to help? I'm trying to learn not to leap blindly into action.
Richard
Posted: 20.04.2016, 00:39
It's not in the main menu, you need to open the Settings window, or click F12, then go to View > File/folder list > Sorting tab - and there you can find several options to view folders as files.
