FTP connection fails to save
Posted: 07.05.2016, 18:11
by michal
If I want to save new FTP connection and save it the following message appears (FC makes no attempt for connection actually).
So I can only establish the connection through Connect button but it does not save the connection then.
FreeCommander XE 2016 Build 720 64-bit donor on Win10 Pro
Re: FTP connection fails to save
Posted: 07.05.2016, 18:17
It is a bug, fixed for the next release.
Workaround: please use only ASCII characters in the connection name.
Posted: 26.05.2016, 23:17
by michal
Solved with release 723. Now I can see the list of connections (they were actually saved but not displayed).
