724 - Copy full path as text Popup menu actions not removed
Posted: 09.07.2016, 16:07
I tried to remove few items from the button "Copy full path as text" menu, "Copy full path as text (8.3)" for example, but the items are not removed, I tried also to restart FC. I don't need all items there, so is it possible to remove them?
Adding new item(s) works good.
Re: 724 - Copy full path as text Popup menu actions not remo
Posted: 18.07.2016, 21:15
New items can't be removed either, in 725.
Posted: 18.07.2016, 22:37
We have currently the same popup menu for "Address" and "File container" toolbars.
Please remove the desired items from both toolbars and restart the program.
Posted: 18.07.2016, 22:51
I tried, FC crashed, same error dialog as before...
Then I tried to remove the same items from both panels, file container and standard tab, no crash, but it doesn't work after FC restart, still.
Perhaps I need to do the same for all opened/locked tabs?
EDIT: I tried the same in the test version, for address bar and file container, no other tabs opened, still doesn't work.
I tried also with default settings, still doesn't work.
Posted: 19.07.2016, 22:09
Fixed in 725-1 test version, not public, thanks.
