727 - Cursor position issue
Posted: 12.09.2016, 01:03
- use FC file operation for copy/move
- use "make queue button as default in the operation dialog" option
- move item with the splitter move button
- in the Settings tab enable option "Auto minimize when starting the operation"
- click the Queue button
- now select any item
- click the Move splitter button
- file is moved correctly
= but the mouse cursor position is changed to upper left screen corner
I can confirm this also with the Copy button, with my settings.
FC 727 x64, Win 10 x64.
Re: 727 - Cursor position issue
Posted: 16.09.2016, 20:26
Maybe fixed for the next release.
Posted: 17.09.2016, 00:08
Fixed in 728, thanks, Marek!
