Small icon in Address Tool Bar RESOLVED
Posted: 09.10.2016, 11:50
Looked through the forum for a resolution to this problem with no luck.
I had to go and edit the settings file manually. [fcToolbarAction_Address], and change Visible=1
UseBigIcons=1. Then chose size required BtnSize=30 for example.
To find location of ini file, go to TOOLS, Backup Settings, and note directory Usually user/appdata/local/free commander/settings, or similar. Save changes, exit program and restart all should be good. Icons now much easier to see, especially on higher resolutions. If unsure, backup settings before making changes. I don't know why the option for this is greyed on in settings.
